Heater matrix bracket?
Before we set a match to the car, what are we doing wrong here?
What's happening is that the seals are not holding the water back and it's simply ****ing out.
It looks like there is alot of swarf around the o-rings, are you sure they are clean?
and have you checked the mating half in the bulk head?
Deffo clean, the mating is as tight as we can visibly check. The left one appears to not be crimping somehow.
Next step is to check the bracket is straight, hammer time.
Ok, so the plate is as flat as it should be however the left doesn't look to be slotting in correctly.
It sounds like the two halves of the joint are simply not mating properly, if the O rings are pushed fully into their sockets they simply cannot leak so they're obviously not getting pushed all the way in, clean everything thoroughly and use vaseline to lubricate both halves of the joint so they mate properly then bolt it in place.
Vaseline is being used, :-)
Oh my, how frustrating this is. The bolt is tight, yet pipe just doesn't appear to be slotting in correctly so the seal isn't holding the water
Next steps, flip the brack over
Looks like a bit more brut force, a very naughty word and a bottle squeaky fart managed to get the sodding pipe slotted.
Now to run it for a while and monitor the water like I did my son when he first slept at home!
Just seen his thread, I'm suffering like mad to get these pipes to sit properly and seal. I think my bracket might be mullered though.
I'm gonna have to watch this thread as I need to do this soon.  I've been running water without antifreeze/coolant for the past 4 months and someone pointed out to me the other day I might get limescale build up  :|
Thought I had got mine sorted but just been for a test drive and it's leaked all the coolant out again...
How tight do you have to actually do the bracket up that holds the pipes in? I thought I had done mine tight but maybe not. Either that or the pipes weren't as well sat as I thought they were.
sent from my Galaxy Note 3
Drop it out and just buy a bottle of G12/13 coolant (can't remember which) and your sorted as the coolant is a lifetime item so should never need to be replaced.
Just pinch the bolt up, it doesn't seal the pipes, it just stops the sealed joints coming apart, over tightening it will just distort the bracket.
