Help
Hey all!
Does anyone know if a 7 1/2"J 16" H2 rim will fit a 2002 1.4 Mpi Fabia Estate? Ive asked a lot of people but none could give me a straight answer.. The tyres are 215/40/R16
If anyone can help, please write back
Thanks!
Is it 5x100?
Oh and what's the offset?
215 on a 7.5j is a bit big. I find that 215 tyres rub on my Fab.
What's the pcd of the wheels?
They have an ET of 35, and yes 5 x100..
So the inner edge of the rim will be about 130mm inboard of the hub, add a bit on for the tyre, I think there could be rubage.
Hmm.. So maybe I should not use them if the tyres will rub..
Change the tyres and you won't have any issues.
I run 215's on my 8j wheels. They're totally fine on the rear.
Fronts is the only ever so slight problem. Just do it.
