anyone heard a dpf rattle sound
I have a 2007 vrs 2.0tdi pd with a rattle sound coming from dpf area ... anyone else had a rattling dpf ?
Sam
The DPF is right up against the back of the engine, can you be sure it is the DPF?
There are several heat shields in that area, their flimsiness means they are easily moved / knocked and they then start to rattle.
Ok i will check thanks ! If not think I will book in at dealers for a check.
