Meguiars headlight restorer
Just used this stuff on my headlights and was very impressed. Just thought i would share my positive experience!
Very nice results there!
Perhaps you could share a bit more detail on application method/technique etc?
There may be others interested in this sort of detailed work.  :thumbup:
Looking good!! Was it easy? Expensive?
Its very easy to do. i masked up around the headlights to avoid contact with the paintwork. You will need a battery drill, start off  on slow speed then once your steady go onto high speed. Use small amounts of the polish provided in the bottle. If you have stubborn bits then there is a separate pack which includes different grades of paper , i never needed to use this though. I spent around 15 minutes on each headlight.
 I would recommended buying it off amazon
http://www.amazon.co.uk/Meguiars-Headlight-Restoration-Kit-Lights/dp/B001O7I7FS/ref=sr_1_1?ie=UTF8&qid=1400687885&sr=8-1&keywords=meguiars+headlight+restorer
its from eurocarparts so the delivery is very quick!!
to finish off i used a clean cloth and some autoglym show shine to clean off the excess polish
Loving the Reg plate
If you were from Yorkshire yuo could have had
B1 GUM
( ee by Gum )
