I'm sure this isn't right
You can rule out heated seats, that's a green plug. IIRC yellow is for airbag. Previous owner/ first owner must have specced side airbags.
That's definately a seat airbag connector. Clearly your cars had a seat swap at some point. It's easy to tell if you have side airbags as the seat sides will say.
If not find a resistor. But bear in mind there will also be one on the passenger side!
If I turn my car on without putting on my seatbelt it flashes that symbol at me. Must have a sensor somewhere
No wiring or sensors at all in the seats or seat belt buckles :)
Pretty sure that light just comes on with ignition regardless, will try it after work in a bit ;)
The car don't have heated seats its got normal seats, it did have leathers in im guessing the leathers had air bags, so could be to do with them but not on the current seats..
Also the wires do disappear into the carpet and yes its In both rear footwells
Previous owner is a douche for removing the leathers
Boils my pi55 when people start stripping things and making a complete balls up of things for an extra couple of quid
Edited by BigJase88
yeah exactly this is the seats that got taken out
Anyone know if they are air bag seats?..
And the car if any one knows it..
Edited by Haych123
They're seat surgeons leathers, not sure if they can retrim airbag seats.
I'd just scan it, see what comes up and go from there
Edited by matt1chelski
Same seats as mine those by the looks of it.
Has a tag stitched onto the side saying...'air bag.'
Say's Bisto on the side of some buses, but doesn't necessarily mean they sell it.
Have a look on the big sticker under the boot carpet; you're looking for a three digit code 4X1. If that code's listed, the car originally came with side airbags.
I have a se with a disc changer built into the seat, and thats the same plug
That's not for the auto changer, auto changer one is a flat black type connector
you can code the side airbags out with vcds , then just tuck the wires back under the carpet and all is well again, can also code the seatbelt warning out of the dash Kev :)
