What are the correct springs for my car
I have been trying to find the correct part code for oem replacement springs for my car (2006 2.0 TDI 16v (BKD) DSG) with the PR codes G07/L14... I have come across the KYB ones (RH1713) and was wondering if the DSG equipped car needs stronger springs than say the manual equivalent? Anyone know?
Thanks,
Chris
Just phone your local VAG dealer's parts department and give them your registration number, their computer system will have the OE details.
Tried that... Wouldn't give me the part number over the phone (company policy!) and thus the only way to get it is to order it (and then you have to pay up front for the part)...
Just been and looked at one of the front springs and it has what appear to be two pink paint marks followed by two white ones... As VAG cars don't seem to use pink I am assuming that it is in fact violet (although it looks like pink to me!). I also have the suspension codes G07/L14 in my service schedule book / decoded from elsawin. A look on partbase.org says I should have:
6N0411105C coil spring. coil spring; for models with; heavy duty suspension; 1 paint mark; 5 paint marks; green; white; sedan:; PR-G07/L14
What the hell is going on... Has somebody just fitted the wrong springs (doubtful as they look old so are probably the original ones)...
Help :)
What is the suspension code in the boot?
I have a set of spare springs from the same car but manual and I think they are pink pink white white. Will have a look next time I go down if you like.
Hmmm I looked for the codes in the boot the other day and couldn't see a sticker under the floor mat however I have all the codes from a 1 hour session of elsawin... Any idea which ones in particular as there are 186 in the list I printed out!!! :D
If at first you don't succeed, try, try again...
I found several local Skoda dealers also tight lipped and unhelpful however another VW dealer was more than happy to help and got my business.
If Skoda won't help you can always try VW or Audi.
Didn't that list include decodes for all the PR numbers? And a duplicate of the missing sticker on the boot floor is also inside the front cover of your car's Service Schedule booklet.
This is the list from my service schedule:
E0A = No special edition
1D0 = Without trailer hitch
5SJ = Left exterior mirror: convex
5RV = Right exterior mirror: aspherical
1KF = Disc brakes, rear
6FB = Body-colored exterior mirror housings
1AC = Anti-lock brake system (ABS)
3FA = Without roof insert (standard roof)
1N3 = Speed-related variable steering assist (Servotronic)
1NL = Covers for alloy wheels
HH7 = Tires 205/55 R16 91V
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4R4 = Power windows with comfort operation andcircuit breaker
3NW = Rear seat bench/backrest, split folding with center armrest
3QT = 3-point seat belts with tensioner and height adjustment, front
4X1 = Side air bag front
4A3 = Seat heater for front seats separately controlled
8L3 = Roof antenna
J1D = Battery 380 A (72 Ah)
7AH = Electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
8GU = Alternator 140 A
6Y0 = Without cruise control warning system
9AK = Climatronic with impact pressure control free of cfc
8RM = 8 speakers (passive)
7Q0 = Without navigation device
8YL = Radio with CD player
8QL = Key for locking system with remote control
8X1 = Headlight washer system
4K3 = Radio remote controlled central locking operated from inside and safe securing
B09 = Type approval Great Britain and NorthernIreland
G07 = Front shock absorption
QN1 = Drawer under left front seat
3PJ = Electric seat adjustment with memory system right, left seat mechanically height-adjustable
9P1 = Seat belt reminder, electric contact in buckle
7X1 = Park distance control
9W0 = W/o car phone preparation/installation
8WB = Front fog lights
7A2 = CD changer
3GA = Without cargo area
QG1 = Service interval prolongation
0GG = Emission standard EU4
L14 = Suspension range 14 installation control only, no requirement forecast
7P8 = Electrically adjustable lumbar support for right front seat
F0A = No special purpose vehicle, standard equipment
3S4 = Preparation for roof load rack
2UA = Standard design
Yes I listed what I thought were the two relevant entries above... G07 & L14, which are listed online in various places but the paint codes on my springs do not match what partsbase says are the springs for G07/L14 (See post #4).
In my extended listing from ELSAWIN I also have 0YD (GKH?) Weight range 4 installation control only (Something to do with towing weights maybe?), Also G07 L DFV - Front shock absorption and L14 L GKV - Suspension range 14 installation control only.
I did do a search before creating this thread and somebody else has previously asked the same question but nobody answered.
Ideally if somebody out there has a 2.0TDI (BKD) with DSG of a similar vintage and could check their springs to see what paint marks they have, that would at least answer the question of if these are likely to be the original springs or not.
/end ramble!
Just noticed this on partsbase:
1K0411105BD coil spring. coil spring; 2 paint marks; 2 paint marks; violet; white; PR-2UA/L14
This fits the description at least for what I have fitted at present!
I just wondered if anyone had lost the book and got one from a scrap yard.
Not in my case (1 previous owner with FSH as far as I can tell).
OK so it appears my car uses the same springs as the VW EOS! I used the russian online version of ETKA to investigate which returned the 1K0411105BD part (matches my PR codes and has the correct paint marks too). Now to find somewhere that has the equivalent part e.g. Kilen 25062
Thanks for all the suggestions etc gents,
Chris
