Rear springs Fabia VRS MK2
Morning everyone.
Has anyone changed rear springs on the above car......lowering with Eibach, but been quoted £350, so was going to attempt the rears myself if its easy - any specialist tools needed?
The more I save, the more I can spend on other mods :)
Not specialist tools needed, just a socket set, axel stands and a car jack.
Get the car up on the stands, undo the lower shock bolt, use the car jack to take and pressure off the shock when removing the bolt. Do this on both sides before trying to get the springs out so the axel can drop enough. Pull the springs out and replace. Dead simple
Here's the bolt to remove
Thanks for that.....if I had the stands I would defo give it ago.....booked in for Wednesday - can't wait.
