warning lights on dash
hi new to this hope you all ok today on way home the dreaded warning beep sounded and my traction control flat tyre and abs warning light all lit up i stopped straight away switched off for a min then started again within 20 seconds driving all 3 came on again so switched off again on starting again within 10 seconds again all lit but only 2 mins from home so thats where it is now its a 2010 petrol vrs 27000 miles drives brilliant all tyres good brakes good any help please....thank you
Could be a number of issues but likely to be the failure of an ABS sensor on one of the wheels.
You'll need to get the fault code read for an accurate diagnosis.
Welcome to Briskoda by the way!
+1 sounds like an ABS sensor fault.
More likely if it will sometimes go away until you drive over 30mph.
I think your car is too new to suffer from the Teves Mk60 problem.
thankyou lads i'll have a word with my mate his mate has got garage hope he will plug it for me and find out what the fault code is
