Electric seat memory not working?
Hi,
I picked up my 55 plate Octavia L & K last week and I'm not sure the driver's seat memory buttons are working. The electric seat adjusts fine, but nothing seems to happen when I press "set" then one of the numbered buttons to try to save my settings. Also nothing seems to happen if I press one of the numbered buttons to retrieve any stored settings.
Any ideas? Thanks in advance for any help :)
Gemma
sounds like either a loose connection or faulty memory seat switch, it can be pushed out from under the seat to check the connections,
if the connections are fine it will likely be a faulty switch and a replacement one can be obtained from your local skoda dealer.
Thank you; I will investigate the connections tomorrow. Hopefully it will be a cheap part if faulty!
I don't think the memory switch is that expensive and from memory I think it was about £35 when I replaced mine a few years back.  If working properly it should make bong noise after pressing "set" followed by one of the "number" buttons.
How long do you press&hold button?
I tried various lengths of time, with ignition and engine on and off, and couldn't get any of the buttons to make a noise. I followed the instructions in the manual so I suspect there's a problem.
no more than a few seconds it should make a bong noise and your seat position should be stored, the memory seat switch is not waterproof so it can be easily damaged by rain entering through an open door/window, and if you have vcds cable you should be able to check if the switch is faulty.
Edited by wiilydog
