Irritating rattle on vrs
Ok so I've found out this much
It's defo from outside and appears to be from rear off side I've checked the rear arb bushes exhaust heat shields pipes nuts bolts wheel centre caps brake pads etc
It only seems to do in on uneven surfaces It's as though something is loose and it bangs once for each bump!!!! Could it be trailing arm bushes??
I'm even looking and fuel filler cap I've emptied the spare wheel well I'm going to start hitting it with a sledge hammer until it stops
top mounts
top mounts
On the rear???
Spring?
Just dragged the wife outside withe her glass of wine and pjs
Turns out its the shock absorber bush can these be purchased individually ??
