Spare Wheel
Good afternoon all,
Ive just purchased a FL VRS but took the spare wheel from my 58 plate VRS to swap over due to the dreaded gas system.
But ive been told that it wont fit is this true?
if the spare is a 15" wheel, then yes it's true, it won't fit over the front callipers.
You need a 16" spare wheel.
Daft question, but have you got a jack too? There isn't one in a 'puncture repair outfit' car (like mine).
My VRS was second hand and came with a spare wheel and jack etc. It was only when I needed it that I found out it had a 15" wheel and was therefore useless :devil:
All MKII VRS with factory brakes will take the same 16" spare. As you had a VRS before, the same kit will be fine.
Whoever told you it won't fit was probably thinking about the current (MkIII) Octavia vRS.
This model has bigger brakes and therefore the spacesaver has to be a minimum of 17" to clear the caliper.
As you are talking MkII vRS the 16" steel from your pre-FL will fit on the FL with no issues.
Yes I have the jack lol.
Its a 16" and fit the mk2 non face lift fine, strange because it was a dealer who told me it wouldnt fit.
Trust me, a dealer getting it wrong or simply making stuff up is far from strange I'm afraid.
lol
I can now confirm after a blow out and a long journey to work, the non FL octavia and FL octavia VRS spare wheels are the same.
Had you had a can of foam it is likely the journey to work would have been even longer!
Spare wheels are worth their weight in gold.
Totally agree pal, and I now have mine firmly located in the boot and the foam is in the side just in case.
  • 3 months later...
Ive just got a can of foam in the boot. 60plate vrs cr hatch. Im looking in to getting a spare and jack but when I had my 18" neptunes off recently I tried it in the spare wheel well and it is about 1 cm too thick so the carpet sits high and floats on the edges, so any weight not directly above the wheel will damage the carpet. Any one else have this problem and any ideas how to get around it? Id really prefer not to have a space saver in there and have a proper alloy.
I have a 16" full size spare wheel with brand new tyre for sale (see for sale section). Its no good to me as it doesnt fit over my big brakes. So i just run with hope i don't get a flat tyre.
In order to carry an 18" alloy as a spare I made up a false floor for the boot out of plywood supported on wooden batterns to support it above the spare wheel.  Have a disc of thin dense foam on top of the spare wheel for extra protection and to support the centre of the false floor.  All that should ensure that I never have a puncture and hence never need the (real) full sized spare wheel!
I have never looked at the size of my spare
Sent from my Galaxy S5
As I have the variable boot floor the slight rise in the carpet isn't really an issue for me, though it does use up a bit of space in the underfloor area. You say your spare sticks up about 10mm. This seems quite a lot compared with mine which IIRC protrudes just a few mm at most. Mine's a vRS estate, in case it makes a difference.
I bought a cosmetically damaged Neptune from ebay and have had it refurbished.  A new tyre is going on this week - all I need now is the jack etc. so I am looking around local car breakers to find a kit in good condition.  The new ones listed on ebay are a bit pricey for what you get!
Can anyone recommend a reputable 'vehicle dismantler' in the Newton Abbot/Plymouth area?
