vcds
Hi guys
so I've messaged a couple of people in my local area (bournrmouth) about vcds coding.... I'm waiting for my bluetooth module and wiring kit to arrive and once installed it needs coding??? But haven't had any luck fitting someone to do it can any one help willing to pay!!!
thanks
if you know what to code happy to help but may be a bit far :notme:
John
Well i have a bolero unit which hasn't got factory fitted bluetooth...... i be Brought the correct unit but once I work out how to fit it i need it coded in so it will work
If you're up near the midlands I can help you out! I fitted the ceiling mounted Bluetooth kit to my octy and have a bolero unit but didn't need any coding, the bolero has 2 mute inputs...but that's not saying that y won't? :)
Oh Ok so I might not need to code it.... hopefully once I install the unit might just work
