Hi My skoda is a bike engine I have fitted a asz engine in it the crank sensor
Is the only thing different they are both 3 wires
Is it possible to wire then one on asz engine to loom of bkc engine
Also is the bkc engine flywheel does it have the pin for the crank sensor to pick up on it
You are trying to put a mk1 engine in a mk2 car. The ECU for the BKC is very different to ASZ ECU.
I've used all my electrics off the car only thing differs is the crank sensor
Also I just noticed the plug to injectors are same colour just in different pins cheers for any help you can give
I have used the cam sensor off the asz and the crank sensor as bkc runs off rear of crank but asz runs off front of block
As the crank sensor had the 3 wires I presumed it would be the same
1 negative
2 signal
3 live 5.v
  • 1 year later...
1 negative
2 signal
3 live 5.v
Did you get this sorted ??
