vrs performance
A stupid question i know as heat causes loss in power. But due to the recent hot weather has anyone else noticed a drop in perforamnce at higher speeds.
Heat soak!
Can it be significant on these.
Air con off of you want to retain power
I've heard it can reduce turbo spool!
Cheers guys
no. no loss of performance... FMIC doing a good job :)
May be worth claifiying for other users if it's standard or not?
mine is standard... I'm compairing it to the mark I with the side mounted intercooler, that you could feel loose about 20 bhp after a few hot starts! beinf front mounted in a good place, give good cooling :)
but undoubtely boss, a bigger FMIC would reduce charge temps more, and that can only improve things ;)
