Fuel gauge stuck low on fuel
Hy all,
on my fabia 1.9tdi '03 the fuel gauge is stuck low on fuel, also the indicator light for fuel is turned on when i start the car, and my board computer is shownig about 30kilometers left even when I put fuel in the tank.
what could be the issue causing these problems?
Everything else is working normally, this happend two days ago and I thougt it wolud go away but it did not.
any advice?
The problem is probably with the fuel level sender in the fuel tank. It's not likely to throw a fault code since what would you measure as faulty?
The most likely failures in a typical sender are a leak in the float, or a failure in the level measuring device (usually a rheostat).
Fuel gauge works on sender in tank sending current from earth via a variable resistor to guage. Simple way of isolating fault. Remove lead from tank sender unit . Gaugeshould read empty. Earth lead and aguge should read full . Does this- sender unit is faulty.
