clutch cylinder is worth a closer look at
hi I recently got a clutch cylinder from the brakers yard I seemed fine until I was bleeding it and it popped apart
spring went flying out oil everywhere,,, after a closer look I realised there was a black horseshoe clip which holds the spring
and pump together was worn so got the took out the clip from the old one (cylinder was gone altogether) and fitted it to the
one got from the brakers yard sorted to my relief..  just makes me think how many clutch cylinders have broke over one simple
clip at the cost of about 50p
                                              lol michael
Where are you want to do mine. Lol
have two correct my last post the clutch slave cylinder broke and got that sorted . and now I have an arkward
clutch cylinder two replace after I put two much pressure on the cluch pedal and damaged it am looking everwere
for a cable the things hydrolics... what a pain this will be a patience tester when they made this car could they
off not kept it simple and easy to excess it
