bluetooth antenna
Hi all where has everyone put there bluetooth antenna I've placed mine the the top of the passenger windscreen looks fine from the inside but shocking on the outside as you can see the 3 tape...
thanks
I put mine in the middle of the windscreen above the rear view mirror
Sent from my SM-G900F using Tapatalk
That's not a bad place no so obvious... just for some reason it fitted with grey 3 tape rather than black
Ohh mine came with the 3M tape on it already
Yeah mine did too but it's grey for some reason
here's mine.
u won't notice it from the outside, unless u look for it.....closely!!
Wedged mine behind the stem of the rear-view mirror and didnt use the tape at all. To be honest though as my phone does not do rsap then I could just as well have stuck it anywhere or not connected it all.
here's mine.
yeah thats were i fitted mine..... looks fine sat in the car but looking outside in you see the horrible grey 3m tape
I took the side trim off the side of the windscreen and hid it under there.
Signal is still strong but it's completely hidden.
Phil
ah now thats good idea if it really annoys me there i will move it to your position
