Fitting HIDs (rear bit!)
Normally the rear of the headlight are rubber so easy to cut and fit HIDs. The mk1 VRS has a hardened black plastic cover. Anyone fitted HIDs? And how did you tackle the plastic?
Thought about drilling it with one of those circual drill bits then fit a gromet?
Sent from my GT-I9505 using Tapatalk
Easy, use a holesaw
I know but what about sealing it back up. Wont it start fogging up etc.
I had them fitted, mine just had a small nick out the edge of the cover just enough for the wires to sit in, cant say I had a problem with them misting up
Oh, my bad, either use a grommet or gaffa tape. I didn't have any grommets large enough when I did mine, so tape it was! I haven't had any trouble with them fogging up yet.
Thanks. Will give it a go!
My passenger side headlight cluster has been missing the plastic inner cover since before i bought the car 2 yrs ago.
Not once has it fogged up...
Drilled a hole and fitted a grommet on mine. Not fogged up so all good so far.
Interesting. I am just going off previous. My old passat> didnt fit the rubber back properly. Slipped off and my headlight condensated up to death. Took ages to dry up in winter.
I have ran mine with out covers for months now :\, no fogging up just dead fly's ha
Mine never ever came with the covers the previous owner must have ate them… no probs what's so ever with them fogging up
