Noise from clutch
hi....i have a squeaking noise from the clutch when pressed and released even with the engine turn off.you can hear the squeaking noise from under the bonnet.the clutch it s not slipping it's normal
The car is a octavia vrs 02 plate
Any suggestions?
I have the exact same noise. The DMF on mine is also on its way out so clutch and DMF changing on Monday. Presuming that noise will disappear with the DMF noise!
ok....so that is bad news for me :(
the sound comes from the pressure plate wich is failing
