ASZ INLET MANIFOLD . AND EGR DELETE
felicia16v
OK guys I have this asz inlet manifold which has been completely decoked and cleaned inside. Ideal if yours is coked up and you didn't want to spend 5 hours cleaning it. £20 collected
Also have my egr delete which allows use of the original boost pipes And has a threaded hole to take a boost gauge nipple or can be blanked if not used. £15 collected .
Could do a deal for both together and I can arrange postage via signed for courier
Hi mate, do you know the difference between the ASZ and BLT inlets? I have a BLT but I have deleted the egr/cooler setup so I suspect this would fit?
sent from my Galaxy Note 3
Guest
