cruise control?
Also wondering how the cruise control is operated properly. What do the res+ and set- buttons do as well as on off and cancel? Any help appreciated thank you :)
On off cancel:-
Off position - off obviously!
On position - on....
Cancel, use to um cancel your set CC. spring return to on position.
Set - use to set your current speed and to decrease set cc speed - push and hold until desired speed reduction.
Res + use to resume previous set CC speed after it has been cancelled by one of the following - cancel switch, brake pedal or dipping clutch.
Res+ can be used to increase speed while CC is active, press and hold till desired speed is reached.
HTH
Sent from my XT1032 using Tapatalk
Edited by fairlight5
While it is engaged the + and - buttons can also be clicked to achieve about a 1mph increase or decrease in speed too.
Phil
Thank you
