help i cant get the interior lights to work :(
At the drivers side end of the dash (with the door open) there is a panel, which you prise off and you will see the fuses. The layout of the fuses on the piece of card attached inside the fuse panel cover and the layout in the handbook are a mirror image of what you see because it shows a left hand drive car with the panel at the opposite end of the dash.
hi again i checked the fuse and it was fine and i got a m8 to use his vag-com thingy on the car and is said it has a open circuit fault shall i take it to a skoda dealer as it still has warranty until january ?
