v clamp between dpf and turbo .
Does anyone had a problem with the clamp between turbo and dpf?
On my 1.6 tdi cr 2010 I have an air leak black smoke and noise when engine is cold.
It wont have the metal gasket fitted.
Thanks for your replay.
Is that an expensive job?
A mechanic told me I need to change the clamp and the gasket.
Pretty sure they will be under £10
  • 1 year later...
Hi, I have the same issue. New clamp is fitted, but it happens again just after several days. Do you have any solution now?
