Part number needed, or name
Does anyone happen to know the name of the "I hope this is not self explanatory" The kind of carbon press-stud head shield cover that covers part of the charge pipe that sits underneath the drivers side of the engine.
Mines fallen off!!!!
Drew
Do you mean this :-
ITEM 6D Boot.......Part Numbers :- 06A - 145 - 867F /  06A - 145 - 867Q
One covers turbo exit 90deg hose, other is where you describe, think the one you want ends with F.
NB: Click on pic to enlarge
Hi Mate, I think that is the one, There are three on the system, one on the top of the charge pipe on top of engine, second is below , and third which i need is at the back at the bottom of the engine the you can access it from under the drivers wheel arch at the back of the engine, is this correct.?
Cheers for your reply matey....
Drew
Yes,
That is the one.
In this pic?  Pic is rubbish but its a 90 degree boost pipe with two heat wrap things on corners, with pop buttons.
https://flic.kr/p/o6SYud
Thats the one I am after, cheers lads
