Lambda wire question
Does anyone know what colour wires are the positive and negative to the heater element in the front lambda sensor as mine has fault code saying open circuit...
Hoping someone knows to save me some time.
Sensor has been swapped so it is pre harness plug
Anyone?
Anyone?
the heater wires must be both same color
Whys that?
What engine?
It makes no difference which way round the wires go in the heating element circuit, essentially it is just a resistor anyway, hence why they are normally the same colour.
AUQ
so hopefully there will be 3 different coloured wires and 2 the same
Pins 3&4 are heater circuit, pin 3 is blue/red, pin 4 is white.
you're a star thanks a million now I can just check the resistance to see which is dead
The resistance of the heater should be 2.5 - 10 ohms at 10 degrees
The lambda itself is fine it's the wires going to the harness under the car
