Brake Pipes/Hose's
When fitting the 312mm disc's the hose supplied is too long, the one already fitted is a bit short. Can you get them "made up" so its a bit longer than the short one but shorter than the long one? :confused: If so any idea on price?
If you get the TT brake lines that are supplied with 'Golfturbo' kits they are perfect.
OK...I thought I have read on here that they are a tad long and the OE are a tad tight :) Thanks for that I had some supplied with my Discs :thumbup:
I fitted a set to Bens on saturday morning and they were perfect.
TT brake line's it is then. Thanks Lummox..................Andy
My TT brake lines were too long. I used the normal ones which hooked up to the calipers just fine. :D
I think my mate told me using the TT ones would cause a pinch along the line its meant to run. Not sure.
Ive allways found the original pipes to be just fine. Once they are on they dont stretch. Also the flexis shouldnt rub anyhow.
Can I say 'I told you so' to the super duper master techie type brake guru man :thumbup: :P .
Good to see you today mate - pity we didn't talk more!!
The hoses for the TT are actually 90' out of alingment for the fabia but if you gently introduce a twist between the chassis connection and the horshoe clip on the strut they are perfect.
