Torque & ODBII Diagnostics
Hi all
I recently forked out the princely sum of £2.97 for a Bluetooth ELM327 ODBII dongle.  Took a few weeks to arrive from China but it's the best 3 quid I ever spent!
I've paired it with the android Torque Pro app and I love the graphic displays for various different readouts.
There is also an ECU fault reader which I can imagine will be immensely useful if I ever get a fault light.  It also performs a live test - the results of which are below:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.3499
Test result value: 0.92086
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.62074V Min: 0.62074V
Test result value: 0.62074V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.29906V Min: 0.44969V
Test result value: 0.9494V
PASS
MID:$02 TID:$81
Max: 0.62074V Min: 0V
Test result value: 0.61098V
PASS
MID:$02 TID:$82
Max: 1.29906V Min: 0.62074V
Test result value: 0.6305V
PASS
MID:$02 TID:$83
Max: 0.1597V Min: 0V
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Max: 65,535 Min: 4,096
Test result value: 8,257
PASS
MID:$3d TID:$80
- EVAP Monitor (0.020")
Test incomplete or dependant test failed
MID:$3d TID:$82
Max: 9.99393 Min: 0.09516
Test result value: 0.0979
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,239.90002°C Min: 754.90002°C
Test result value: 820.29999°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 1,024Ohm Min: 0Ohm
Test result value: 114Ohm
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
End of report.
2 things in the test are concerning me.
1)  Firstly, the EVAP monitor - Test Incomplete of dependent test failed - is this an emissions test failure right there? Any Torque users know if this needs configuring in Torque beforehand or does the sensor just not exist (or is it on VW's proprietary protocol and therefore can't be read?).
2)  I have a reported misfire on cylinder 3.  An average of 1 misfire on each 10 drive cycles.  I'm assuming there are 2 sensors per cylinder but only 1 of the sensors is recording the misfire.  I've re-run the test numerous times and it's always logged as a count of 1 no matter what the driving style is (idle / urban / throttling the arse out of it) so I'm wondering if it's anything to be concerned about?  I would have thought that if it was a random misfire it wouldn't always be recorded?  Additionally, the test still reads as 'PASS' so the system must be seeing it as a random misfire?
i cant help much with the first one but regarding the misfire fault, thetest MID:$a4 TID:$0b looks like and average figure to me so the car is averaging how many misfires the car has had over the last 10 drive cycles. the max figure this can be is 65,535 and the fact you only have 1 doesn't concern me very much. i think if it got a lot worse then it might be worth putting some new spark plugs, ht leads and coil pack in (providing yours is a petrol engine) however 1 every 10 drive cycles isn't a particularly huge figure to me.
Andy
Thanks Andy.  I'm having it serviced next month so they should be able to resolve it for me (I'll be a little suspicious of their abilities if it's still registering a misfire after the service!!).  What I couldn't get my head round is that it was always a constant 1 in every 10 each time I ran the test.  I would have expected some tests to yield a count of zero.
