Pesky kw coiloverness - help
Guys...... Its driving me mad now :D
I want the front done another 5-10mm ish
But.... Im out of threads on the passanger side :(
Im sure i asked for the black limiter bushes to be took off when had top mounts done
Trouble is there was 2 per side so wondering if 1 is left lurking on that side
How easy is it to check for these bloody things before i rip of the kw and go for fk silverlines for the drop
7BAF51C5-3765-44AA-A145-A4B58A2627A1_zps
It's because kw Coilovers have been designed for performance and handling
And slammed means crap handling lol ;-)
lol im hoping that i find 1 black thing left on the passenger side :D
Lol
Those black things are just bump extenders, so unless you are leaning on them, they won't make a difference to right height dude. You should get poly top mounts buddy as these will lower your car 10mm with your KW's
But you can check quite easy if you Jake car up and see on strut shaft how many on each side. I think I still have 2 per
Ok dude, i will have a nose, im sure they took them off
I got powerflex top mounts, do they lower it the extra 10mm too or is it only certain ones
  • Sponsor
Powerflex top mounts don't lower any more, we do have the Polybush ones that lower a further 10mm though.
Damian @ DPM Performance
Cool, i will swap to them when the time comes
How much be them mate ?
  • Sponsor
Replied to your email yesterday Lloyd.
Cheers dude :)
On the case of extra bits so can do all at once, then i'll get them ordered
No they don't lower but Poly bush ones do and also you could use both the Polo Top hat plus the Polo top mount as that would give you 10mm drop as well.
P/N's
two x   6N0412319 = £9.10
two x   6N0412331A = £15.54
Example of these verses the VRS ones
before fitting Polo Bushes
After
On it :)
I shall try
Poor powerflex mounts being evicted lol
But sorry.... Need more lows ;)
Well..... Want :D
