fitting boost guage
Hi people
I jave a boost gauge to fit but cant see where to feed the pipe through the bulkhead to inside the dash? Ive seen a fitting guide on here with big pointy yellow arrows but im stuck at this point
Anyone able to help with somr pics?
Remove scuttle pannel and you can make a hole through where the wires go from engine bay to drivers feet
Pop the scuttle trim off then on the drivers side there's a black cover drill that and fit a grommet to make it water tight. The cover is behind the fuse board/ relay plate so comes in a good spot for feeding up to the gauge.
Edited by chrisw4266
There is a grommet at the bottom of the passenger footwell, on the bulkhead. I run my vacuum line through there :-)
