Intermittent Oil pressure sensor light
Have tried everything to solve this problem,changed oil pump,big end crankshaft bearing,oil pressure switch,still light comes on turning corner,on roundabout,accelerating,never on idle and only when oil heats up,any ideas welcome please
Forgot to mention,2011 octavia 1.6 auto dsg
Could be a problem with the oil pick up from the sump.
Cleaned and checked that,no sludge oil to begin with,seems fine,even bent it slightly,approx 10mm so as it was closer to the bottom of the sump
Oil pressure relief valve?
Is it possible to attach a oil pressure gauge so that you see if the pressure is actually dropping when accelerating and cornering?
I'll look into that,it's driving me mad,not to mention the money and time spent trying to solve it,cheers
