Flip Key Upgrade
Using would of instead of would have mate ;)
I see
Some of these folk aren't half picky are they.
I blame writing how I speak, the Lancashire dialect doesn't put itself to paper very well [emoji17]
JRJG
Two button non flip keys can be swapped for two button flip keys, but if your car has no boot release button already then the third button on the key will not work, just look pretty
What if the key looks like this?
Has no buttons but when you put the key in the door and turn it, it unlocks all the doors similar to Central locking.
Think a 2/3 button flip key can be programmed to work?
foe netty callie :)
If you have no remote, probably not. Look in the boot for the build codes and look through the thread on here to determine if rcl was specced when new. If just central locking then a remote cannot be coded to the ccm (central convenience module)
Same bloke and great service. He done mine
22163A4C-5BB7-45D6-AD08-06F9B2CAFDFD_zps
BBF7194B-3504-40D5-AB20-65AABB38280F_zps
Looks pretty nice ... but please excuse my curiosity. What's the purpose of a button for unlocking the boot of a hatchback if it doesn't really go all the way up? Does it unlock only the boot and then you have to push the button to open it and unlock the doors to get in or you have fitted a stiff spring somewhere to pop it up when it's unlocked and/or opened by remote?
It pops open as far as if you pull the lever on the inside of the car. Some cars such as mk4 golfs can have kits fitted with stiffer dampers so it opens all the way when it is opened on the key
That makes sense ... are there any dampers that might fit a hatchback to force it open all the way? Maybe the ones from an estate version would do the job ?
I would of thought you'd need a different boot operating 'latch' / lock if you wanted anything to happen when you pressed the 'boot open' on the three button flip key. As currently the car won't have the ability to unlock just the boot.
I cannot imagine it being an easy process. Although I could be wrong.
This does actually work on my car. Got myself a fob of fleebay and programmed it to the car using old key in ignition trick. Boot now pops open when using the fob, although I'm going to need to clean / refurb or replace the motor unit on the latch as it's not working first time every time and sounds a little strained. Just need to get someone to code the immo chip so I can use the one key instead of having both on the key chain.
