Tfsi using Water possibly
Sure my water level /coolant was higher to the half way point and now it's on the first line of the two marks, What's it mean if it uses water? I mean I do give it some beans quite a lot but
Check the car at the same temperature. It can go up and down a bit just with temperature.
I had to top up my Octy occasionally between coolant changes but only by a little and not often (like once in 2yr).
Check the oil filler cap to see if there is a lot of coffee colour crud, a little bit isn't an issue.
Also check the expansion tank for a scum of oil.
They would point at a head gasket.
If you don't have either of those things then it's maybe just a little vapour leak in the expansion tank, a drip at the pump or a leak in the radiator.
No grubby in the oil, expansion bottle is fine,
water leak from water housing on the battery end of the block.
or leaky rad... i know mine is leaking.. but its £300 to replace:\
