Adjusting MPG on a 2010 FL octavia - How to?
goshow
It's under Instruments in VCDS.
Then adaptation > Known adaptation values and choose fuel consumption correction (could be called something slightly different).
It should be set at 100%. For an over reading dash you increase the percentage. Generally around 2% per 1mpg over. So try 105%.
Phil
Cheers guys. Yes I've checked the mpg over the last few months using the brim technique. It's been reading high on every occasion.
I'll give it a go.
Well, I'm plugged in to VCDS, gone to "Select Control Module", 17 - Instruments, Adaptions - 10 and had a good search down the list but there are several options that "could" be for adjustment, nothing obvious. However, whenever I select the options  I get "ERROR - Channel not available"
Hmmmmm. Any suggestions
