Here's an odd one !
Columbus unit.
Sat nav – works
Radio – works
CD – works
ipod – works
SD card – works
Leave car in hot sun for a few hours, return to car, now,
ipod and SD card do not work and are not recognised
Run car with Air Con on full for a hour – still don’t work.
Leave overnight and everything is back to normal.
If I leave the car for a few hours in a covered car park and return, it’s not so hot inside as it was in the sun and everything is OK.
I find it hard to believe that the heat can have this effect. I have could understand if the CD did not want to play as it’s mechanical, but the ipod and card reader are solid state.
Has this unit got a life of its own?
probably a life of its own. update the firmware if you can
Yes, I've had the occasional 'funny' like that as it has been a very hot summer and leaving the car closed up raises the inside temperature to something like a pizza oven. After a few minutes with doors open or air-con working it sorts itself out. I don't function normally when cooked so can't expect Columbus to do so either .
