Temp reading on radio
Hi
 after upgrading to a f/lift Octy from pre f/lift , SWMBO is missing  the temp reading on the radio, is there a way to get it on my Bolero via vcds ?
Not that I'm aware of, but it should be selectable in the instrument cluster :)
Doesn't need to be selected in the instrument cluster, it is always there?  It certainly is on mine, although mine does have Maxidot.
In MaxiDot it's always there, in the non-MaxiDot you have select it in the same way we can scroll through the instant econ/avg econ/avg speed/range etc on MaxiDot.
IIRC only the old Stream and Audience headunits displayed the temperature on the radio, neither the Columbus or Bolero have the capability.
Thanks for the replies.
Don't have maxidot  so she'll have to stick her arse out of the window to tell the temperature then.  Ha Ha               :devil:
In that case it will be one of the options on the display, you'll need to scroll through using the buttons on the wiper-stalk :)
Now that's what you CALL a display..........................
