Octavia MkII Dash Panel Fuse Details (2006 1.9PD L&K Estate)
_____________________
| 01 02 03 04 05 06 \
|____07 08 09 10 11 \
|____12 13 14 15 16 1718192021 |
| 22 23 24 25 26 27 28 29 30 31 |
| 32 33 34 35 36 37 38 39 /
| 40 41 42 43 44 45 /
| 46 47 48 49 /
______________
01: Diagnostic socket 10A
02: Control unit for ABS, ESP 5A
03: Airbag 5A
04: Heating, Air conditioning system, Reverse lights 5A
05: Control unit for headlamp beam adjustment 5A
06: Instrument cluster, Control unit for automatic gearbox, Control unit for electromechanical power steering 5A
07: Telephone preinstallation 5A
08: Towing device 5A
09: Not assigned
10: Not assigned
11: Parking aid 5A
12: Central locking control unit 10A
13: Diagnostic socket, Light switch, Brake light 10A
14: Control unit for automatic gearbox, Selector lever lock 5A
15: Central control unit -interior lights 7.5A
16: Climatronic 10A
17: Not assigned
18: Parking aid 5A
19: Not assigned
20: Uphill-Start off-Assist 5A
21: Not assigned
22: Air blower for Climatronic 40A
23: Front power window 30A
24: Cigarette lighter 25A
25: Rear window heater, Auxiliary heater 25A
26: Power socket in the luggage compartment 20A
27: Fuel pump relay 15A
28: Not assigned
29: Engine control unit, Crankcase ventilation heater 10A
30: Injection valves (diesel engine) 10A
31: Vacuum pump 20A/Control unit for Haldex coupling (4x4) 5A
32: Rear power window 30A
33: Electric sliding/tilting roof 25A
34: Not assigned
35: Anti-theft alarm system 5A
36: Headlight cleaning system 20A
37: Front seat heating 30A
38: Not assigned
39: Control unit for automatic gearbox 20A
40: Air blower for heating and air conditioning 40A
41: Rear window wiper 15A
42: Wipe wash pump for windscreen 15A
43: Towing device 15A
44: Towing device 20A
45: Towing device 15A
46: Heated windscreen washer nozzles 5A
47: Relay for auxiliary heating 5A
48: Not assigned
49: Light switch 5A
Edited by MicMac
| 01 02 03 04 05 06 \
| 40 41 42 43 44 45 /
| 46 47 48 49 /
______________
03: Airbag 5A
09: Not assigned
10: Not assigned
11: Parking aid 5A
16: Climatronic 10A
17: Not assigned
18: Parking aid 5A
19: Not assigned
21: Not assigned
28: Not assigned
34: Not assigned
38: Not assigned
48: Not assigned
49: Light switch 5A
Thanks for that will go threw them tommorow
Update on my side is new sump arrived today
Will drop it to garage tommorow for it to be fitted and get service
A1D6CC4C-DDA1-4273-8601-051DA0F05600_zps
Hopefully its the correct one
  • 2 months later...
Which fuse if for front wipers
Edited by DanialA11
  • 7 months later...
The front wiper fuseon under hood fuse box in the top side of driver side there are 2 fuses
  • 3 months later...
HI Can you help tell me where is the Relay for the Radiator Fans and also Fuse for the Music System
  • 2 years later...
Hi,
Where is the fuse for the rear wiper, please?
BIG THANKS:)
  • 3 months later...
Can any 1 tell me wer abouts the 147 relay is  pls
