Any Pics explanation
has anyone got pics of removing the centre consol in furby vrs?
anyone done it any pointers?
:D:D:D
Which bit? You mean all the HU/buttons thing? Because thats quite tricky - lots of TORX bits. ;)
was hoping not to have to go that far but may have to :thumbdwn:
just wanting tips on the part that surrounds the transmission tunnel and the cover leading up to the actual dash(below the heater controls)
thanx :D:D
The bit around the "transmission tunnel" is very easy to remove. I think there's just 4 or 5 torx screws holding it in place. IIRC, they're in the front ashtray and under the rear ashtray (Elegance) or rear open storage hole (vRS). To get to the rear ones, you just need to pull out the ashtray/storage hole. You need to pop out the plastic trim under the handbrake to lift it over and also lift up the gear leaver gaiter (?) to manouevre it over that. I believe the bit of surround trim directly under the heater just pops off once the transmission tunnel bit is removed.....
I did have some photos of when I did this a year and a bit ago - I'll see if I can dig them out......... :D
Chris
It has some velcro on the bit under the heater controls.
Can I ask why you want to get under there?
it was for speaker wire to run my front comps. down from hu to amp in boot.
did it today :D
also ran 4awg down passenger side(couldn't believe how easy it was :cool: )
and 3 rca and remote down drivers side.
hardest part was putting all the trim back on, why must everything overlap :finger:
in the guide to run power cable when it says not to fully remover the door sill trim (don't do it ) it is an absolute nightmare to go back on :finger:
would take some pics but the interior looks completly standard :cool: apart from the ends in the boot and the bundle i stuffed in behind the hu.
thanx for all the help guys
