Would these fit?
Hi,
Just wondering if these would fit on a Felicia, they are BMW e30 alloys which are 4x100 7jx15
So hopefully someone can enlighten me
Yes possibly, you would need a spigot adaptor though becuase the centre bore of a bmw wheel is larger than a vw group wheel.
okay nice, thanks for the help, but i've just been searching around and it says that the centre bore is 57.1? Isn't that the same as the felly's?
Edited by shambrook
Also the offset is less than the felly's, does that make a difference?
Yes the offset makes a difference
Use a calculator, like the one found here http://www.willtheyfit.com/ to work out the difference between your current wheel and new wheel.
Also you can mess around with tyre sizes to give you better clearance (stretch)
Edited by ClarkE_123
I thought bmw wheels had a 62.6mm centre bore?
