Wheel hop
Anyone else suffering from pretty bad wheel hop under hard acceleration? Happens mostly on wet surfaces.
This is with TC turned off.
For those wondering what this is: http://www.mc2racing.com/tech/20061012a/
Edited by johnabrahamsen
No, all seems to happen pretty much as it should, mind you, I have a DSG.
No problem to wheel hop with TDI and DSG, till TC is coming in takes a little time.
I have the 1.8TSI DSG (180hp).
Which is faster than the VRS TDI at 7.5 secs 0-60 (compared to 8.2). I find it hard to believe the 2.0TSI does not wheel hop though?
An 'anti lift kit' will help eliminate this. Many people make then, I opted for the White line variant & certainly made a difference. With need wheel alignment done after though as it changes the front end geometry.
Sent from my OnePlus One
I only get it on my TSI vrs in the wet on poor road surfaces. So I'm more careful now.
I think its the high compliance rear control arm bushes that allow the geometry to change and the wheel to move forward and backwards. A poly bush in there would reduce it but also reduce ride quality...
I think suspension in vrs makes it a bit more difficult to hop wheels but with Revo stage 1 they hop like crazy even when roads are dry.
I said wet I meant to say damp, wet just lights up lol.
I'd imagine with a revo map it would be far easier to break traction and end up in a situation which the wheel could hop. I'd say tyre choice could play a big part too.
My last pd140 Passat used to batter its suspension with really bad wheel hop if you were not careful
I have had it a couple of times when I've tried launch control...
P
What tyres do you have?
Sent from my HTC One_M8 using Tapatalk
Im using the ones that came with the car. Michelin something.
