Oil leak + coolant leak
Hello just abit of help needed with my 2011 1.6 tdi monte this morning I had a sudden drop in coolant which brought the light on I topped it up and it's been fine ,what would randomly cause that? the cars done 71k and I carnt see any leaks under the car.
Also while just generally checking I noticed there was pooling of oil around were the injectors sit I think it may be the ruber seals around the injectors? Not sure of there name.
Thanks in advance
Edited by Skodalouie
Turned out it was the water pump that was leaking and the timing belt was in bad shape to when I looked
