Oil pressure gauges/sandwich plates?
Where on the AZJ 2.0l engine can you attach an oil pressure sensor? Maybe a sandwich plate on the oil filter? Easy access on this.
Anyone done this on a skoda?
What are the ranges of pressure for this engine (hot idle and max)?
I've always liked to keep an eye on pressure and temp.
I used a glowshift plate on mine ( 1.8t )
Works fine :)
Works fine :)
I've bought stuff from glowshift before and found them to be reliable. Had a AFR kit with digital display.
I think the plate is the only way to go. That way I can also fit an oil temp gauge.
Most tricky part will be finding a way to feed the cable into the dash I assume.
Really pleased with my glow shift gauges :)
My wires come in with boost gauge pipe, dave sorted my cable routing :D
Sandwich plate?
sub-sandwich1.jpg?1289963431
