clutch problem ?
my felicia is driving me crazy, i have a problem of car not getting into gear once stopped, not always, sometimes it goes in easy but most of the times not, i changed the transmission fluid, replaced clutch cable and adjusted it flush with the brake pedal, it is still hard to shift gears. any answers will be appreciated very much thanks
It sounds like the clutch is not fully disengaging when the clutch is depressed.
If it is difficult to get gears with the engine running, but easy when the engine is switched off, you have a clutch problem.
yes its difficult when engine is running only, when its off its very easy to shift even without clutch... also when it gets stuck at lights i blip the throttle to like 1500rpm and it sometimes slips in gear
