G60 VR6 Clutch, worth it? any good?
my clutch is on its way out, thinking of getting a kit from techniclutch ebay.
Have any of you had this conversion? is it decent/ reliable?
cheers
dave
cheers
dave
Don't buy from Techniclutch - do a google search https://www.google.co.uk/#q=problems+techniclutch
A slice of edam would be more use than anything from techniclutch.
More to the point, g60 flywheel and vr6 clutch.
I've heard many reports that you get increased vibration and rattle noises from single mass flywheel, however, if you can deal with the noise, then go for it as performance wise, it will be much better.
I am not saying you will get that noise, as some people say it's fine. But it wasn't worth the risk in my case, so I went for a LUK dual mass flywheel and clutch. Had them before on other cars and they have been fine. The are an original brand that car brands use in their own cars.
Hope this helps.
OEM G60 flywheel and VR6 clutch. Pedal is much lighter and will cope with more power. And is silent !
I've heard ones which are not silent. So just depends I suppose. Luck.
I believe its noisey on those tractor engined car but on the petrols its fine
Plus 1, my conversion has been worth every penny. Gives you alot more confidence when pulling off.
There is no luck involved  I had genuine g60 and vr6 clutch and flywheel from vw main dealer fitted on my old vrs sweet as a nut nice and light and no vibration and held the power with revo remap no problem,the only time you get a small vibration is when you fit a yellow powerflex dogbone bush so I swapped for a softer red powerflex diesel dogbone bush no vibrations .
I bought mine from tecniclutch. Sachs clutch and it was fine, I don't get any vibration either. As far as I know all there branded stuff is fine. Just don't touch there uprated stuff.
i have a g60 and vr6 set up on mine.   no vibraton or noise.
my fabia however is a different story but thats a oil burner.
ahaha edam cheese!
ive come to the conclusion that the techniclutch is too cheap to be good. for the sake of 100 quid i dont want to risk having problems.
what do you think of the ecs stage 1 clutch and flywheel kit?
what will the lightened flywheel feel like?
cheers for your comments chaps, i think its good to be able to talk to people and get educated haha
Just get genuine vr6 g60 flywheel job done
ahaha edam cheese!
My flywheel is the ecs lightweight and it works lovely, I'm sure every little helps.
