Need some help guys
Hi everyone. I have a question and hopefully one of your braniacs can help me.
I got my 2005 skoda octavia 1.9tdi 110hp dsg back i nfeb.
When i got it started having issues with abs anyway that got solved after replacing front wheel bearing front abs sensor front abs loom it was abs pump :( anyway that sorted had a starting issue then found the idiot that had it before me put a petrol battery on diesel car so that sorted that.
Had it serviced all filters air and fuel and oil etc.
I had  an issue from the start which was the following.
Sometimes when you get to about 20 - 30 mph the car falters briefly and you can physicaly hear a noise like an un lubricated pump noise as it makes the noise you can feel the car falter its almost like its being choked and then comes out other side fine i have had it happen around 40mph but more common at the lower end.
The car always continues to run never brakes down. I had rac out they said it sounds like diesel pump the noise is upfront somewhere and can be heard i think more if passenger window is down or if you go through a tunnel with windows down you can here it its not a constant noise just happens when it wants.
Had car read no error codes no lights on dash and had my diesel pump replaced nearly £500 and its still there had treatment in fuel still there is there something  i am missing guys its doing my head in lol and i am hoping its something simple.
Heres hopeing i can get some help.
Try recording it on a mobile for here.
its so random and brief would have to have it on all time record and then it might not get it its like it chokes for a second then fine
