side lights with xenons
Hiya ppl. Was wondering if anyone new of a way to change the side light bulbs on my Fabia Vrs. Can it be done without having to take the car to a main dealer????? ( ps car only got delivered today ) dont wanna f**ck it up lol
Should be possible but fiddly DIY if you don't have Xenons.
I have, so I got my dealer to fit my replacement sidelight + dipped beam bulbs. They took the front bumper off to do it. An alternative apparently is to remove the fuel filter and the battery to gain access from the engine bay. Either way, it's not something you want to do often.
It is possible with xenons, but you will need a lot of patience & small hands help!
Unclip the back covers (you will need to unscrew the ballast box from the N/S headlamp) & locate the side light bulb holder. Pull on the holder & it will come out eventually (it will be very tight).
Then you can change the bulb.
Thanks guys. Am gratefull for your help. Will keep you informed.
Hi done a side light bulb upgrade took me 1 hour 30 mins had to take my battery off to make it easyer I am glad I done have to do that again
