Fabia 2 Reversing sensors disable while towing
To disable reversing sensors while towing remove fuse 12 10A  adjacent to the only 7.5 A fuse I could see this disables the sensors and light.
One step further fit dummy/ blown fuse attach a fuse holder with  10A fuse to one terminal and plain wire to other terminal of the dummy connect a  push button switch to the wire ends drill fuse cover extreme left there is more room now you can disable at will .
