SKODA OCTAVIA MK1 OSF DRIVER WINDOW GLASS
 I need to replace driver side window glass  on my mk1 skoda hatchback 2000  tdi eletric window do you know if only the hatchback will fit or the estate version are the drier window glass  the same, i have a local scrapyard that have mk4 golfs
does anybody know if any of the window glass will fit or i  need to order one from for the hatchback version from  ebay thanks  also would anybody have the proper part number for temperature sender got one from ebay but need to return no
good . thanks  Gianpaolo.
Gianpaolo
They are the same shape between Combi and Sedan - however you may wish to check that the tint is the same. Have a look at the codes stamped on the window base corner and compare with what you find either at the scrap yard or on eBay... A cheap fix...
David
