Brake Fluid...Just checking......................
if all Dot 4 brake fluids will mix.....Having the BIG Brakes done soon :) so I'll get some Brake fluid.........Halfrauds own will mix with say....Castrol Thanks Guys Andy
You must have read my mind!!
I've just bought some Castrol Super DOT 4.
I can read people's minds "I'm Septic" :) .Will Super Dot 4 mix with Dot 4 :confused:
I think it will.
What I'm wondering is:- Is it worth just topping up with the Super DOT 4 or bleeding some fluid out & then putting in a litre of Super DOT 4?????
Bear in mind, I have a track day this Sat.
bleed then add super dot 4
Or have a vacuum change over and filled from empty with super
:thumbup: Cheers!
Any need to bleed the rear calipers as well??
not sure with the fabia to be honest.
I'm not sure either! :)
If it does, then I think you have to bleed the rear calipers with the axle loaded , i.e. resting with the axle stands at the end the trailing arm.
Anybody confirm that?
Right then, e-mailed my mate to see if the Fabia has a bias valve.
He seems to think it won't have one due to the ABS sensors, etc.
the octy has a brake bias valve and it has the ABS sensors etc.
Post a message in "ask a tech" or send a PM to "Lummox"
He will know for sure ;)
