Quick query about a ko3s turbo
Just got myself a ko3s turbo as my vrs has a ko3 on. I've got the 053 one which is a unsilenced one, just checking this will go on ok and be alright. Only paid £60 for it so that's why I took what he had as when I was googling it there's 3 types of ko3s, the 052 is a silenced one for the vrs then there's 053 and 058 ones all have same 85nm actuator on it so I've presumed they all fit
A1E8B1C7-0885-4439-955B-3FEFFD28FB89_zps
62830656-29EB-47BD-9F5C-A49016289908_zps
EB2F2371-C66D-491F-9FA2-55BF0987AB2A_zps
34369748-9C73-43FE-AF60-263397D08121_zps
Picked it up and no play in the shaft :) all looks good. So as I said before there is the 052 which is the silenced vrs one this is the 053 which is the aum 150 turbo but as far as I'm aware this will hold the same power as the 052 and then the 058 was fitted to the anni golf. Does anyone know why the vrs had a silencer on it???
Im sure someone on here fitted a 053 model on there vrs and had issues with lack of boost because it was from a golf. I also had no idea some where silenced etc.. Strange
Well I'm running a ko3 at the min so I'm sure this will be a improvement lol. From what I've read about them the golf boys get the same sort of power when mapped up and they run the same actuator so should make the same power more or less. I was more wondering in terms of is there any physical difference but I don't think there is
Your best off having a search on this forum because someone had trouble with theres. Maybe it was a duff turbo i dont know
Copied from the golf forum but to me I read it as exactly the same turbo apart from not silenced or I missing something???
All the following turbos have the same installation dimensions and
thermodynamical performance. The differences are only in the actuator that
opens the turbine bypass valve:
K03-011 (5303 988 0011) 150 hp, 65 N actuator
K03-026 180 hp, 85 N actuator
K03-035 180 hp, 85 N actuator
K03-044 150 hp, 65 N actuator
K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
K03-049 150 hp (Sharan/Alhambra), 65 N actuator
The 180 hp versions have an actuator with a higher opening force due to the
higher exhaust gas pressure (which is a consequence of the higher boost
pressure). Otherwise the valve would be pushed open by the exhaust gas
pressure.
The following turbos are a further development (since 2000) and have an
improved and slightly larger compressor while using the same turbine (still
with the same installation dimensions):
K03-052 180 hp, 85 N actuator
K03-053 150 hp, 85 N actuator
K03-058 150 hp/180 hp, 85 N actuator
Ko3 - 97-2000
COMPRESSOR WHEEL
Inducer: 33.6mm
Exducer: 46mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko3S - 01+
COMPRESSOR WHEEL
Inducer: 38mm
Exducer: 51mm
Tip height: 4.4mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko4-015
COMPRESSOR WHEEL
Inducer: 35mm
Exducer: 50mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 50mm
Exducer: 42mm
Tip height: 6.4mm
Blades: 11
See here for some more info:
http://www.seatcupra.net/forums/showthread.php?t=35228
Which engines?
Typically K03 are on AGU engine codes on lots of early VAG cars.
K03s = AUM AUQ engine codes from the following :
Mk1 Leon Cupra,Seat Ibiza Cupra, Mk1 Skoda Octavia VRS, Audi A3, A4, Boras
KO3s turbo numbers:
KO3-052, 053,058 or (K03/82 from a Polo GTI) For k03s
If you look into the inlet, the ko3 has 12 fins, the ko3s has 8.
The reason behind the different part numbers was due to one being from the Octavia (silenced version), one from the AUM/ARZ engined Golf/A3 and the other was from the 180bhp Anni Golf/Cupra
