how do I reset the oil change warning notice
need to do an oil change but doing it my self as I don't really need bosh service as its my taxi with no warranty.
what I want to know is will I need to reset the oil change notice on display and how is it done.
In the infotainment systems & car setup menu with the ignition on.
thank you :)
You'll find a 2 pence coin useful for the sump plug
ha I'll remember that next time I can't find my sump screw bits. :)
I sused it out
ignition off hold 00/set on dash wile switching ignition on then let go, then it asks if you want to re set if so tap 00/set again if not don't and it will ignore the command, happy days :)
